4-27-2019 |
4.50 |
Rudder pedal assembly |
Assembled the rudder pedals, applied a thin coat of grease to the pedal arms Drilled in the slide blocks and a set of 1" spaced holes for the slide adjustments. Bolt on the two master cylinders to the pedals D/A'd the pedals and primed for paint. I picked up some gloss white enamal for finish coat. |
