4-18-2019 |
2.00 |
Rear rudder pedal assembly |
Assembled the push pedals for he rear seat rudder pedal controls. Mounted the rod end bearings to the push pedals, with bushings. Drilled the associated holes, disassembled and deburred. Then riveted the rod end threaded rod into the push pedals. Spun on the rod end bearings for assembly. |
