4-20-2019 |
3.50 |
Rear Rudder pedal assembly |
Removed the two bolts on both the left and right lower angles of the gear towers. Bolted on the attachment brackets and marked the inbound bolt locations. Removed brackets and drilled out the second bolt holes. Deburred an rebolted the brackets to the gear towers |
