Date:    4-15-2019
Number of Hours:    2.00
Brief Description:    Mount flap motor to control arm and rivet the rudd
Mounted the flap motor control arm with rodend bearing to the bulkhead mount. Set hardware and drill holes in the control arm off the motor assembly, for wire tie. Wire tie the flap motor arm to the bolt holding the rodend bearing to the bulkhead mount
Rivet the two rudder stops to the rear of the fuselage section
