3-9-2019 |
2.50 |
Bell housing assembly and fabricate the push-rod |
Debur the bellhouse crank. Rivet the two pieces and spacer, with the bearing together. Cut push-rod length. Measure, align, and drill the 8 holes on each end of the push-rod. Match drill the pushrod end pieces and deburr all pieces. Prep and prime the push-rod. Cleaned the inside of the push-rod, pushing a soaked MEK rag through the tube. Priming the inside takes some time to push in the paint and swirl the tube to coat the inside. Then prime the exterior of the tube. |
