1-19-2019 |
6.00 |
interior console and throttle assembly |
cleco and bolt the right console into place. Match drill the two platenut holes into the bulkhead cap on the right side. Remove console and deburr assembly including the edges and holes. Fabricate the throttle cable mount from 2 x2 1/2 angle. Debur mount and holes. Cleco the mount to the throttle structure. Match drill the remining holes into the mount, where it bolts to the throttle assembly. Enlarge the holes in the throttle structure where the cable mount bolts on. D/A and pain the cable mount * I did a practice run at taping the aluminum typical of the mount to confirm fit to the spec screws. (Mount was drying so I was not able to tap the holes) |
