Date:    12-1-2018
Number of Hours:    3.00
Brief Description:    Vinyl wrapped the front seat assembly
I applied the 3m 1080 carbon fiber textured vinyl wrap to the seat assembly. Using the same 3 color process as the rest of the interior finish. White vinyl with black underscore below the wihite stripping. Then I applied the Graphite color top and bottom.
Applied black carbon to the upper and lower angle. Overall excellent finish and I wish I had applied the vinyl to the rest of the pieces prior to riveting, but I am where I am and I'll have to live with the vinyl over the rivets on the side walls. (Probably better anyway, if I decided to change color or paint the surfaces, instead of wrapping.)
I only brought foreward the wrapping vinyl a couple inches of the top and bottom since it will be covered with the cushion/upholstery.
I do like the what the seat back finished up after riveting. (Riveting is recored on separate entry to keep my time correct on the interior finish vs building)
