11-16-2018 |
2.50 |
Tank seal applied to foreward skins |
I discovered that I had missed dimpling the holes for the forward cooling plate to the firewall. I drilled a hole in some 1/4" plate and set the femail dimpling die into the plate for a bucking bar. Set the male die in the hole and with the help of Jenny, use the rivet gun to apply the needed pressure to dimple a hole. (Really worked great, didn't take much to dimple the firewall) Then mixed up 80 kg of tank sealant and used a sandwich back with a cut corner to apply the sealant to the edge of the firewall and for rivets of the forward skin. Set pieces and clecoed the assembly together. |
