Date:    11-2-2018
Number of Hours:    2.00
Brief Description:    Attaching main gear legs
Bolted the inner gear, bracket, and wear plate on both the left and right main gear legs.
Squared the fuselage to the floor lines and set up the plumb lines on each leg to verify the alignment of the gear legs. Set in the outer brackets and wear plates with the 3/16" clearance from the outer side skins.
