8-21-2018 |
3.50 |
Side Skin riveting and assembly |
Back riveted the middle Longerons to the left and right rear side skins Cleco the rear skins to the fuselage/mid skins and upper longerons Rivet the Stabs on the 811 rear bulkhead. Match drill the lower holes to the 409 WD tailwheel assembly. Match drill the 1/4" holes in the tail wheel assembly to match up to the Slab assembly and tailwheel weldment'' Trim the tabs on the very far end of the Longerons |
