5-10-2017 |
2.25 |
Leading edge assembly and tanks |
Finished riveting the leading edge to main spar assembly. Attached hardware for Pitot tube to main spar/skin Set tanks into place on main spar. Attached everyother screw in skin assembly to spar and doubler plate. Losly bolted in the ribs to main spar. (I'll have to go back and tourqe down the bolts to proper specification. I need to check on possibly safety wiring the bolts. I'm a little worried about vibration on the bolted connections inside the wing. |
