Date:    11-12-2016
Number of Hours:    3.00
Brief Description:    Cleco and match drill ribs to main spar assembly
clecoed the ribs from the leading edge assembly to the main spar. Match drill and final drill new holes in the two ribs next to the eyebolt tiedown.
I fluted the two most in bount ribs on the leading edge assemblies. Bent and slid into place the doubler plate between the leading edge assembly on both wings. Clamped, drilled, and clecoed the left leading edge assembly.
