5-20-2016 |
2.00 |
Fitting rudder to stabilizer and fiberglass tip |
Fit fiberglass tip to vertical stabilizer. It required cutting and fitting fiberglass to achieve a smooth transition between rudder and tip of both fiberglass assemblies. Debur/dimple skin and tip. Rivet fiberglass tip to stabilizer I attached the rudder to the horizontal stabilizer (measuring the 3 bearing assemblies as per the print measurements. |
