4-16-2016 |
8.00 |
Left elevator assembly |
Rivet the electronic trim system to the access door. Rivet nut plate hardware to access door. Rivet trim assembly. Rivet spar assembly for elevator Rivet root rib to spar with flush rivets then rivet elevator horn assembly Bend elevator trim area and bend both sides fo the elevator trim tab piece |
