12-9-2015 |
2.00 |
Engine runup |
Ran engine for 15 min. Checked for leaks. Discovered leaking fitting on braided hose from block to oil pressure sensor. Removed hose and leaking fitting. Cut off 1/4" of the hose and installed a new fitting. Reassembled oil pressure sensor hose and ran engine for additional 15 minutes. Leak checked. No leaks |
