10-23-2015 |
7.00 |
Engine Installation |
Installed cylinder head temp probes and EGT probes. Installed the Dynon EMS220 wiring harness and connected the fuel pressure sender, oil pressure sender and oil temp wiring. Ran the EGT and CHT thermocouple wires but did not connect. Completed wiring the alternator and voltage regulator/rectifier. Sealed most of the extra holes in the firewall. Firewall supplied by RANS is predrilled for the Rotax 912. SInce I am not using the Rotax engine many of the predrilled holes are not used. |
