Date:    8-8-2015
Number of Hours:    5.00
Brief Description:    left wing leading edge wrap
Dimpled all holes in leading edge wrap and leading edge wrap stringer. Clecoed in place. Sanded contact area between leading edge wrap and spar with 120 then 80 grit sandpaper. Flush riveted stringer to wrap and then wrap assembly to ribs. Cleaned contact ara with MEK then isopropyl alcohol. Mixed a batch of adhesive and applied to contact area with a large syringe. Clamped leading edge wrap to forward spar. Allowed to cure overnight.
