Date:    7-10-2015
Number of Hours:    2.50
Brief Description:    Brakes and door trim
Tightened all brake fittings, bled brake lines by adding brake fluid at each wheel fitting. No leaks and brakes work properly. Added foam strip to both door trim pieces.
