Date:    2-28-2017
Number of Hours:    3.00
Brief Description:    deburred,dimpled prepped,primed right elevator fra
Deburred all ribs and spar for right elevator.
Dimpled ribs and spar with subframe 3/32 set.
Had to use tight dimple method on aft 2 holes on the ribs. Suspect I may have to use the MK319BS pull rivets on those as well. Will try regular method first, at least on the top.
prepped all riibs and spar then primed.
