Date:    1-5-2019
Number of Hours:    2.00
Brief Description:    Started to contour left elevator tip
Started the contour process on the left elevator tip.
Mixed West Systems 105 resin with 206 hardener and 407 low density filler.
first attempt was too thin so i wiped it off and added more filler that had better consistency.
Applied it to the area that I wanted to blend in and set to harden.
