4-5-2020 |
6.00 |
Weight and Balance |
Weight and balance measurements. 7 qt oil, no fuel, all internal and exterior panels in place. No gear fairings; will add those later in phase one, initial flighs will be without gear farings. Right wheel: arm: 69.20", weight 513 lbs. Left wheel: arm: 69.50", weight 529 lbs. Tail wheel: arm: 239.38, weight 64 lbs. Empty weight: 1106 lbs Empty CG: 79.77" See associated W&B documentation for full CG workups for various loading configurations. Aircraft CG limits per Van's documentation. Fwd limit: 78.70" Aft Limit: 86.82" Aft limit (acro): 84.50" |
