3-28-2020 |
6.00 |
New fuel level sensors, rudder connections |
Replaced the Dynon fuel capacitive sensors with Princeton 1S units. They original Dynons were very insensitive (seems to be a known issue); the Princeton units work much better ... higher output range. Added the rudder cable / pedal links. 3" center to center is the initial setting based on hangar flying. Will test and adjust. |
