2-9-2020 |
8.00 |
Wing pushrod and fuel plumbing |
With the aileron alignment board, do an inital setup of the aileron pushrods using the bellcrank alignment tool. After, a very slow process of adjusting the long and short pushods to bring the ailerons in line with the flap TE. Fortunately I didn't need to put a nut on anything till the very end. Torqued nuts and jam nuts. Completed the plumbing lines from the tanks to the fuse. |
