8-12-2018 |
3.00 |
Initial fit of alternator and fan belt |
Installed the alternator brackets and alternator. As a test fit, I installed the flywheel and fan belt supplied with the alternator and found that the belt was a bit short; with the belt in place, the body of the alternator was touching the prop oil line. Clearly, this is not desired. I will order the next size larger belt and check the fit. Fortunately, this is only a $5 fix. |
