Date:    5-14-2016
Number of Hours:    6.00
Brief Description:    Drill canopy hinge brackets
Another high stress operation: drill the hinge brackets on the canopy frame. 100% Cleco all the skins in place, clamp frame in proper position, and carefully drill through the guide blocks into the hinge ears. Once the hole is established, remove and finish on the bench. Centering and edge distance is acceptable.
