Date:    3-29-2015
Number of Hours:    8.00
Brief Description:    Fuse reassembly2
Adjusted and reinstalled floor and floor stiffeners
Placed temporary 1.45 inch spacers in slots betweent the F-704 A and B bulkheads, loosly installed bolts and F-905 spacers between F-704 A/B. Double checked the rivet holes for 704 A/B to be sure when the rivets go in, the spacing will be locked in properly.
Finished up the fitting of the 623A attach straps for the F-623 corner rib on the baggage floor.
The armrests have been reported to be relatively fragile, so I decided to do a stiffening job per on of the threads on VAF and and add a bit of J-channel to the inside edge. This is an easy and light weight mod, and makes the arm rests much stiffer.
