3-7-2015 |
8.50 |
D&D fuse side skins, priming of fwd fuse parts |
Deburred and dimpled both side skins on the C-frame; needed an extension table to handle the size of the skins. The ordeal was not as bad as I thought; fewer holes than the wing skins. Following deburring dimpling/countersinking of the parts, they all went through an alumniprep bath and then primed with Stewart Systems smoke gray EcoPrime. |
