5-31-2014 |
5.00 |
Left wing internals |
Finally, back in the shop after too many other things to do. Installed the aileron brackets on the left trailing edge, Installed the left bellcrank and torqued all the bolts. It took 4 off/on cycles to get the brass bushing burnished properly and everything lined up to make the pivot frictionless once eveything was torqued down. Installed the snap bushings for the pitot/AOA lines. Primed the aileron gap and flap reinforcement fittings. Primed the long pushrods and end fittings. |
