2-14-2008 |
5.00 |
Antennas |
I took the upper antenna back to Sparkchasers with the intention of swapping it for the bottom mounted antenna. I talked with Billy one more time and he changed my mind again:) Dan made up some one ended coax cables so that I can mount the antennas and run the coax. We'll terminate the coax at Sparkchaser's shop when we wire the panel. I sure wish I had Jeff's sheet metal break nearby. I'm using a vise with aluminum jaw extensions. It works for stuff that will be out of site. |
