Date:    11-11-2006
Number of Hours:    4.00
Brief Description:    Servo mounting
I was anxious to work on the aileron servo mounting. I had thought it was going into the wing but after talking with Greg at BMA I decided to try and fit it under the floor pan as he suggested. I ordered enough parts from Van's to put it in either place. As it turns out, it will just fit under the floor board. I'll need to find a tap to retap the hexagonal bar that I cut to fit and I will have to add a doubler to the floor skin. It really cuts down on the wiring from the controller to the servo.
