Date:    6-10-2008
Number of Hours:    7.00
Brief Description:    ELT and flap work
Work on RV with Terry. We mounted the flaps, made the flap connecting rods, installed the flap connecting rods and cut the fuselage for the rods. We made an elt antenna doubler plate, riveted the plate and mounted the elt antenna.
We trouble shot the fuel senders and BMA engine pod. We later found out that the BMA does not work with grounded sensors and I had to order nylon shoulder washers to isolate the senders.
