Date:    10-1-2007
Number of Hours:    8.00
Brief Description:    Build and install battery box and heater box
Lennie is coming on Tuesday so all the holes and things behind the engine must be done today!! I built and mounted the battery box and heater control box. I drilled the prop, mixture and throttle cable holes. I drilled and prepared the starter solenoid and master soleniod stiffener and plate nuts. Lennie and I will have to rivet these before mounting the engine. Installed engine mount.
