Date:    8-30-2007
Number of Hours:    4.00
Brief Description:    Continue on gear and riveting
Worked on nose gear fit and got the gear stuck in the motor mount. Thankfully Lennie came by and lent his "weight" to the motor mount so that I could get the gear unstuck. It took more sanding until everything fit. I'm changing the bolt to a taper pin based on what I've read about nose gear failure on teh RVs.
