Date:    12-3-2006
Number of Hours:    3.00
Brief Description:    Preparing to repaint
If it warms up any this week, I hope to repaint the bad spots in the fuselage. I still get flamed when I see the sloppy mess that Larry Estes let out of his body shop. I hope that the new apint color matches what they put on.After sanding, I started working on the instrument panel area. I'm putting in the quick canopy release so I need to locate the pull handle. Then I can finish the instrument panel layout. I'm putting the engine instruments below the instrument panel so that the instrument panel can be pulled out with having to deal with engine cables.
