Date:    5-26-2008
Number of Hours:    9.00
Brief Description:    Getting wings ready to go on
I drilled the front wing support and installed the plate nuts. I installed 2 cockpit eye ball lights to illuminate the breakers and switches. I fabricated bracket for flap position sensor and mounted the flap position sensor. I then installed the aileron push tubes. The wing is ready to go on permanently!! I then worked on the gear fairings.
