11-1-2015 |
4.00 |
Attached windshield to fuselage and drilled rivet |
Used tape to attach and align windshield to fuselage. Then use 4mm drill (with 10mm drill stop) and drilled holes in fuselage using pre-drilled holes in windshield as a guide. Inserted cleco after drilling each hole. Everything went well except for bottom right. Had a very slight bubble that I could not work out. I should have stopped drilling and re-tensioned the windshield by re-taping. There should be enough play when I over drill the windshield rivet holes to work this bubble out. |
