4-23-2016 |
4.00 |
Installed Beringer connectors to brake lines |
Slid ferrule nut over brake line, Used a small screwdriver to work braiding around inner plastic tube to expand and push back to make room for ferrule to fit over the inner plastic tube. Pushed ferrule on to plastic tube, Worked steel braid back over ferrule. Slid plastic tube/ferrule over small tube on brake fitting, then tightened ferrule nut to 10Nm as stated in Beringers instructions. Repeated for other brake line. Installed both fittings on the Beringer parking brake. |
