Date:    1-20-2016
Number of Hours:    1.50
Brief Description:    Assembled airbrake and installed in wing.
Put locktite on all the treads and assembled the left airbrake. Riveted the cover stablizer brackets on the airbrake. Should have used Clecos to hold the brackets after drilling the first hole. The bracket moved a little so I had to ream out the hole a little to get it to fit (used a #20 drill instead of the 3.5mm drill because that is the correct drill for this rivet. Not critical but won't move around slightly now).
Still need to remove some material from the left side of the brake. Didn't realize that it moves from side to side when opening, so I need a larger gap on the right side of the cover to allow for this movement.
