8-30-2015 |
2.00 |
Cut holes in firewall upholstery and firewall heat |
Use a sharp utility knife to cut through the firewall heat shield before attaching upholstery, then attached the inner firewall upholstery and used a red hot screw driver to make small round holes it the leather and insulation. I then used a red hot screw driver to melt the insulation behind the two large holes (nose wheel steering and cable pass-thru). Used a sharp exacto knife to cut through the leather. |
