2-1-2016 |
6.00 |
Prepared right wing |
Finished grinding the root edge so it has 2mm clearance with the fuselage, cut and tapped plastic wrap on wing to hold plastic on and keep debris out. Prepared speedbrake slot for marking and grinding. Drilled 5mm holes in bottom of speed brake pocket. Ground out gas cap hole, ground out pitot tube hole. |
