Date:    4-14-2018
Number of Hours:    0.50
Brief Description:    Installed door latching mechanism on left door
Installed door latch using 243 loctite on bolt. Greased inside of barrel on latch pin so it can rotate, used 243 loctite to install nut on latch bolt, installed barrel, installed washer and lock nut with 243 loctite. Left it loose enough for barrel sleave to rotate
