Date:    11-18-2017
Number of Hours:    3.00
Brief Description:    Installed fuel lines and pass-thru plate on right
Received the correct pass through plate from Pipistrel (they originally sent me the wrong plate), installed the fuel lines to the fuel tank fittings. Used ty-rap plastic ties to hold the fuel lines on the fittings. Used a screw driver and a needle nose pliers to pull them tight. Applied some super glue to the plastic ties to make sure they don’t come loose. Attached fuel lines from the top vent connection to a fuel line connector I attached the plate. Again used plastic ties to hold fuel line on the fitting. Ran the lower fuel line through a grommet in the bottom of the pass thru plate. Also attached wiring connector and Pitot and AOA lines to the pipes on the pass through plate. Again used plastic ties to hold these on the pass thru pipes.
