Date:    6-9-2017
Number of Hours:    2.00
Brief Description:    Installed sealing foam on oil cooler baffles
First installed lower engine cowling and measured gap between oil cooler baffles and cowl. Applied tape primer (same stuff used to prime surface for Velcro) to the metal baffles. Removed paper from back of foam and applied to the both oil cooler baffles leaving ~1/8” overhang so it will seal when cowling is put on.
