3-8-2016 |
2.00 |
Ground out and mounted Left wingtip light |
Used dremel to grind out pocket for left wing light. Drilled mounting holes, Attached wire and mounted light. Attached 4 wire molex connector on fuselage side, then connected light driver and tested light. |
