Date:    12-26-2015
Number of Hours:    3.00
Brief Description:    Sanded door lexan windows to correct size
Marked windows with masking tape so I have a 2mm gap all around the window. Sanded windows with a belt sander down to the masking tape. Use a palm sander to round the edges. Used a tapered grinding wheel to champfer both sides of all the drilled rivet holes
