Date:    12-26-2015
Number of Hours:    1.50
Brief Description:    Attached locking latches to door latch rods
Drilled and tapped a hole for locking latch ping on both door latch mechanism. Had to grind brass pin spacer so that the screw would reach all the way through the rod. Ground it half round with a dremel so that it will be stronger.
