Date:    8-23-2015
Number of Hours:    1.00
Brief Description:    Mounted Radiator
Measured and drilled holes in firewall for radiator (need to attach mounting bolts before I can mount firewall insulation/upholstery). Mounted upper radiator bracket on firewall. I will leave the lower bracket off until I am ready to mount the engine (don't want to bend them). I will have to cut holes in the insulation/upholstery to tighten but these holes will be behind the engine electronics board
