10-16-2012 |
0.50 |
trim tab wiring |
Drilled a small hole in the forward HS stab and inserted a grommet. Ran the trim tab wiring aft through the grommet. I could not fish out the other end from the trim tab which is in the elevator. Finished filing down the elevator stop. Both sides now have a little more than 24 degrees down travel. |
