Date:    9-13-2012
Number of Hours:    1.50
Brief Description:    fitting the VS and HS
Worked on fitting the HS and VS. Bolted the HS in place temporarily using two of the bolts on the aft end of the HS that go through the two uprights. It still althought moves a bit.
Measured from the end of the canopy rail to each end of the HS. With the HS held in position with two bolts the alightment is right on.
Also put the Vertical Stab in place and determined the bolt hole locations on the portion that attaches to the end of the fuselage.
