Date:    7-22-2012
Number of Hours:    2.70
Brief Description:    install music plug - secure audio panel connectors
Attached 3 pinned wires in a shielded cable to the audio panel J2 connector pins 26-26-28. Tested the other end to verify continuity. Ran the cable through the service loop then to the right side of the airframe, then aft under the top rail on the right side, to the vertical run next to the pilot seat.
Drilled a 13/64 hole in the aft side of the vertical run, marring the finish doing so. I had to open the hole wider with a rat tail file until the music jack plug would fit.
I will probably solder it tomorrow.
While installing the music wiring to the rear of the audio panel connector one of the small red wires broke. I extracted the pin from the hole, attached a new pin to the wire and reinstalled it. That is the second time that has happened with one of those tiny red wires.
I used Goop to secure the wiring at the connector. I installed the stress relief clamp on the rear of one connector. While working with the other connector one of the ground wires that connects the shields of the cable wires came loose. I pushed it back into the solder sleeve it came out of and gooped it. I will let that dry tonight and finish securing the strain relief clamp tomorrow. I will need a screw and nut for that which I may have to go to skycraft to get.
The pitot static parts should be here soon, perhaps tomorrow.
